CleanStream - Remove profanity and fillers in your live stream or recording with AI!
CleanStream - Remove profanity and fillers in your live stream or recording with AI! v0.2.0
OK, so I have an RTX 4070TI, but it's cutting audio out A LOT even with "Whisper Tiny"
Should I use Whisper base instead? Or why is it cutting out so much?
I've been testing this out on my streams recently,noticing that the filter doesn't seem to work when I start my streams and I need to manually turn it off and on every stream. Not sure if anyone else is having this issue, honestly think this has potential to be a great plug in and I want to see it do well!
Can I ask why is this project "⚠️ Stalled ⚠️ This project is not under active development" ? I'm actively waiting (lol) for this plugin to work 100% of the time all the time, as this will allow me and many others to go back to twitch and not be worried about saying something that the rats do not like. I really consider this to be the second most important plugin (after anything that allows you to multistream). Please reconsider polishing it out.
royshilkrot updated CleanStream - Remove profanity and fillers in your live stream or recording with AI! with a new update entry:
v0.2.0
Maintenance release to fix compatibility with OBS v32​
This is not an indication that development is resuming on this plugin
Changes ported over from https://github.com/royshil/obs-localvocal, so they come with bonus acceleration improvements too
Note: AMD variants seem to be currently not working when using hipblas, and MacOS releases may have an issue with Metal on some systems
What's Changed​
  • Fix OBS 32 compatibility and...
Read the rest of this update entry...
Hello,
I'm trying to set this up for my tts program. But it seems to fail to filter anything. Would you know why ?
It works with my own input though
On OBS 32.0.4 something seem wrong, i've took you YT setup guide and done step-by-step in maniacal way, but the plugin seem not working. I've seen also a "debug log" entry in advanced setting, but i've not found any log textfile in any OBS folder/subfolder.
I've tried also keep standard regexp word list and try filter in english, but still not work, also tried CPU and GPU options or different model template.
Little edit to help diagnosys : seem somethign wrong if installing as fresh plugin/addon, the model are not downloaded properly, there is no trace of tiny bin file in whole OBS installation, there is just "ggml-model-whisper-tiny.en.bin" file in default folder, if i move it somewhere else OBS start without bat an eye (no warnings, no errors)
is there a way to shorten the duration of the silience or the beep? so that for e.g. it does not sound like this: fuck > ****, but rather fuck > f**k.
is there a setting for that in the filter options? i couldnt figure it out.
